OctaneRender™ for Blender 2.21.1 - 7.3 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Added the workaround for 2.21.1 engine passes bug (sometimes passes rendering never ended). Now Blender will exit early in this case, so passes SPP value in some cases might be smaller than is set in settings. Will be fixed in next engine version.
Installation:
DOWNLOAD
Blender Octane Edition - v7.3 OSX (88.7MB autoinstaller file)
afecelis
Thanks for the new version JS. This one's working fine again :D
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Next version HERE.
Return to “Blender”
