OctaneRender™ for Blender 2.21.1 - 7.3 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Added the workaround for 2.21.1 engine passes bug (sometimes passes rendering never ended). Now Blender will exit early in this case, so passes SPP value in some cases might be smaller than is set in settings. Will be fixed in next engine version.
Blender Octane Edition - 7.3 (2.73 (59.0MB autoinstaller file)
Octane Server - 2.21.1 - 7.3 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.3 (9.0MB autoinstaller file)
MattRM
Nice !!! That's make my day !!! As the core is 2.21.1, the out-of-core is include in this released for Blender ?
Matt
kubicki3d
Hello JimStar,
Many thanks for this release, good to see imager presets working;)
I see only one problem at the moment - I'm unable to make final renders with "Tonemapped HDR" box unticked. Could you please instruct me how to do this properly?
I made a quick test with just a cube and daylight. When I untick "Tonemapped HDR" the preview works fine, but when I hit F12 I get only "Waiting for image..." message. GPUs work as if they were actually rendering, but no image shows up. Console says nothing.
Szymon
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
MattRM
Yes Tonemapped HDR does the same problem to me when unchecked. Also, in stereo mode side by side, the rendering is not the double for each frame (left/right). the two parts are cropped in the current resolution like this :
the camera aspect ratio is not respect correctly, don't know how better explain.
Matt
MattRM
An other thing a little weird, on an older project done with the previous version is now over exposed / burn without changing something. It's like the texture used for the meshlight don't impact the lighting at all.
UPDATE : The octane texture emission not handle at all color informations. I pluggued color or texture in all slots, not effect at all...
Have you an idea to solved this ?
Matt
Marten74
Solved... (not worth saving the question)
Now I just have to figure out how to erase a message here. Bigger problem then my initial one. Sorry...
thiagodesul
Hey guys, i already have Octane standalone and octane for modo, and i'm looking foward to buy octane for blender also. But i just want to know if octane for blender 7.3 has out of core feature too. See ya, have a nice day! And sorry for my bad english!
hardboilr
The scattering medium nodes doesn't work for me in this new version. Nothing happens when you change absorption...
Win 8.1 64-bit
i7-3930k @ 3.2Ghz
GTX660Ti 2gb + GTX 760 4gb
Next version HERE.
Return to “Blender”
