OctaneRender™ for Blender 2.21.1 - 7.2 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed the LiveDB import bug.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.2 Linux (96.3MB autoinstaller file)
kaiwas
error with "image texture".
http://i.imgur.com/nDQnBUx.jpg
mac3d
Hi Jimstar,i have this problem with ultimate version..
Unknown pin ID 253
Tried to access pin via an invalid ID (253)
Tried to access null node pin
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x7fcbcc6f1ca0)
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
Next version HERE.
Return to “Blender”
