OctaneRender™ for Blender 2.21.1 - 7.2 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed the LiveDB import bug.
Blender Octane Edition - 7.2 (2.73 (59.1MB autoinstaller file)
Octane Server - 2.21.1 - 7.2 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.2 (9.0MB autoinstaller file)
Ide
The OctaneRender™ for Blender 2.21.1 - 7.1 Win [OBSOLETE]
Render Passes does not work.
Activate Render Passes and try to render a simple cube in any kernel mode.
It will render the Combined pass, but other passes will not work. (at least for me)
Final render finished information will be displayed but it will never finish the other passes.
Testing with a simple cube.
If I set the Preview pass type: Wireframe, Material Id, etc..
activate the Render Passes AND Octane Render Layers I will get the passes but not the combined pass.
I think this occurs because there is some kind of loop in Render Passes preview pass type: Combined..
Ide wrote:Render Passes does not work.
Activate Render Passes and try to render a simple cube in anyTesting with a simple cube.
You will never see the Combined pass if it is not chosen as preview pass. This is made just to be able to replace the Combined slot in image editor by any other pass if needed.
I will check the other issues, thank you for report.
J.C
JimStar wrote: DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Still no demo for OS X?
System – Windows 11
Next version HERE.
Return to “Blender”
