Environment settings
wheelpros
Not sure if I am missing it or not but can we adjust the xyz positioning of the environment map. I see we can do rotation but not sure on the other?
Carter
Lewis
I tried it in LW also and no go :(. Only rotation works, even with projection map it's not doing anythign on environment texture, so i guess it's octane general limitation or maybe a glitch/bug.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
wheelpros
Well, did a little digging in Octane Standalone and found out you can adjust the projects y position value there so I would think we could get it in the plugin?
Paul, is this doable as an addition to the plugin?
Carter
Hi Carter - I should be able to add this into the next release of the plugin.
wheelpros
Thank you kind sir! I wanted to let you know that the plugin/integration is fantastic and I am becoming more comfortable with the workings. Hope to post something soon.
Carter
Return to “Foundry Modo”
