OctaneRender® for Maya® 2.21.1 - 6.2 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Switched to 2.21.1 engine.
  • New "Store to OctaneDB" feature in Octane material and texture nodes. You can store to "LocalDB", "LiveDB" or ORBX pressing this button. Experimental at this stage.
  • New "Open OctaneDB import dialog" button in toolshelf. You can load nodes from "LocalDB" or "LiveDB" using standard Octane outliners. Experimental at this stage.
  • Fixed the hair animation bug in "Movable proxies" animation.
  • Minor fixes...
Installation:
DOWNLOAD
OctaneRender for Maya - v6.2 Linux (18.3MB autoinstaller file)
Yours,
The OctaneRender™ Team.
Next version HERE.
Return to “Autodesk Maya”
