OctaneRender™ for Blender 2.21.1 - 7.1 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Merged with Blender 2.73.
  • Switched to 2.21.1 engine.
  • Mute function for Octane nodes is implemented (select node, press "M").
  • Now you can choose in render settings what for HDR you need to render - tonemapped or not.
  • Added Octane render layers. You can set the layer ID in the mesh's Octane properties and enable layers in Octane Layers properties. Global mesh is always on layer "1".
  • Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
  • Added Octane Noise texture.
  • Added "Affect alpha" attribute to specular material.
  • Removed "Keep environment" attribute from kernels.
  • Removed "Start samples" attribute from passes settings.
  • Fixed the camera rotation bug.
  • Fixed imager presets bug.
  • Minor fixes...
Blender Octane Edition - 7.1 (2.73 (59.1MB autoinstaller file)
Octane Server - 2.21.1 - 7.1 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.1 (9.0MB autoinstaller file)
Jozvex
Hi!
For some reason, this new version shows no CUDA compute device in the Blender preferences for me. The only option is 'None' and CPU in the dropdown. Loading up the standard Blender 2.73, everything is fine. It was fine in the previous version of Blender for Octane too.
Any ideas?
EDIT!: Well perhaps it's not such a big issue, I'm still able to render with Octane. I can't render with Cycles in GPU mode but that's not a problem really.
Using Octane in Maya 2024/5
Windows 11
GeForce RTX 3080
Jozvex wrote:Hi!
Any ideas?
These GPU settings are nothing to do with octane. Octane GPU settings are in rendering settings on the panel:
http://render.otoy.com/manuals/Blender/?page_id=42
The settings you are trying to set - are the settings of Cycles, which is not included into this version (I mean GPU mode of it).
lakris
Cool!
@JimStar
Any comments on my questions(requests) in the win 2.15 thread?
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
voon
Haha JimStar .... you cunning present maker. Thanks :)
marcotronic
Nice surprise! :) Thanks a lot!
Marco
Marcotronic - Artist & Composer for Videogame & Film Music http://www.marcotronic.com
00Ghz
this version broke procedural textures in blender. I can't see any preview or effect....
HDRI Editor for Blender : Your own HDRI Studio at an affordable price.
https://gum.co/HDRIEditor
rezman
Hmm...just installed both but for some reason the Blender Octane version comes up just Blender, without the option to choose Octane as one of the engines. Any ideas?
00Ghz
enable the addon
rezman
Thanks! :oops:
Return to “Blender”
