Loading obj through scripts
Forum for OctaneRender Lua scripting examples, discussion and support.
albert29
Is it possible to script octane renderer to load a .obj file and display the result?
I'd be very interested in knowing if this can be done.
stratified
Sure that's possible. For example with this script:
-- create mesh node and load obj file
mesh = octane.node.create{ type = octane.NT_GEO_MESH, name = "loaded mesh" }
mesh:setAttribute(octane.A_FILENAME, "/home/thomas/Documents/obj-files/cube.obj")
-- create render target and connect with mesh
rt = octane.node.create{ type = octane.NT_RENDERTARGET, name = "OBJ render" }
rt:connectTo(octane.P_MESH, mesh)
-- render
octane.render.start{ renderTargetNode = rt }
cheers,
Thomas
albert29
Cool, thanks!
Just to know: is it also possible to "move the camera away"? I can render my sample obj cube but it's too close to the camera.
I'm a newbie so I'm not sure how this can be accomplished. I tried searching for "Scale of view" in the scripting LUA API but couldn't find anything
palhano
Thomas, can you make it recursive so that it will load the entire content of the specified folder?
p3taoctane
This has a lot of potential...
I could not Lua my way out of a wet paper bag.... but seeing this makes me ask...
Is it possible set up a Lua script to load a series of sequentially named OBJs and shatter nodes so that they replace the obj/scatter node currently loaded called mesh_xxxx.01/ scatterxxxx.01 etc so that if
xxx.01 is all rigged up to a render node set to 5000 samples
That it renders out the image saves it with a sequential name and loads the next OBJ/scatter and rinse and repeat???
I have a bunch of scatter nodes that change over time and describe the location of an OBJ that slightly morphs over time but has the same number and named materials. I could load and replace each one and save the file...
But could lua save me the agony??
Peter
Hi Peter,
sure, with Lua you can do what you asking for and much more, like create a specific material and assign it to the mesh or part of it, deeply define the various rt options and so on ;)
I'm a newbie in Lua and basically I cut and paste parts of devs code here and there with lot of tries and errors, but it's quite easy to understand when you dirt your hands with it :D
p3taoctane
Thanks man... I'll give it a shot :D
Peter
Return to “Lua Scripting”
