Bake Sculpt Objects & Octane
kacperspala
Hello ,
What is the proper way of baking normal/displacement for octane from c4d ? I simply cant get anything to work so far, its always ugly/distorted/with black edges/broken.
Any help please ?
ryzer 2700x
rtx 2080Ti
any render samples? You can't bake displacement because points are generated internally in runtime.
ChrisSuF
+1
I think kacperspaia meant baking sculpted meshes within Cinema. I am also having problems with that.
Never found the right way to do it with octane.
kacperspala
Yeah i sculpted with cinema than used "Bake Sculpt Object"
1 - hi-res sculpt
2 - low-res object
3 - new low res object with c4d materials (normal + disp) created after "Bake Sculpt Object"
4 - low-res object with displacement map mapped to octane material
5 - low-res object with normal map mapped to octane material
As you can see object is UVed.
Please help :'<
ryzer 2700x
rtx 2080Ti
can you do some search on forum about this. There is some limitations for displacement and not a issue from plugins.
natevplas
Has anyone made progress on this? I am running into the same issue.
natevplas wrote:Has anyone made progress on this? I am running into the same issue. I actually cannot load anything into the displacement channel of an Octane material in C4D.
image->displacement->displacement slot of material
i'll advice to you this tutorials
http://inlifethrill.com/category-training/
