Why does a render to save take longer than a render to VFB
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
3dgeeks
When i render an animation, saving frames locally, it is 20% slower than the render in Octane frame buffer. Why does this happen, and its not just the first frame, ie the data is already loaded to GPU?
Im using 3x780 GTX 6Gb non sli.
Not really a bug but a major annoyance when rendering animations to expensive hardware. :|
coilbook
same here.
but I noticed if you open octane view port it shows render time after the scene is loaded into the memory where rendering sequence 3ds max shows render time that includes loading data to the memory
maybe this is a problem
visionmaster2
same here.
when i preview a character animation in octane frame buffer its really speed.
But, when i render the animation, its really slower.
any idea ?
valk
for preview in vfb and for rendering to file it is different settings starting from size samples and other ;)
visionmaster2
Can you tell us more, about those settings VALK ?
Return to “Bug Reports”
