OctaneRender 3 for Inventor [OBSOLETE]
Autodesk Inventor (Integrated Plugin developed by Paul Kinnane)
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Inventor - TEST and STABLE releases.
Inventor Version
The plugin requires Inventor 2017-2019, Windows 64bit.
Nvidia Driver Version
This release requires Nvidia drivers 387.x or later.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Inventor version and build number
- OctaneRender for Inventor version (ie. 1.20.1.10)
For more information...
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Inventor/?page_id=563
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Current STABLE build (Octane 3.08.1)
- OctaneRender for Inventor 2017/18/19 3.08.1.22 (64 bit)
Previous STABLE build (Octane 3.07)
- OctaneRender for Inventor 2016/17/18 3.7.0.21 (64 bit)
Release Notes
3.08.1.22 (16-May-2018)
- Compiled with Octane 3.08.1 (see viewtopic.php?f=33&t=63219 for details)
- Added Toon and Metallic materials
- Toon shading only works in Camera Light toon lighting mode
- Added Custom Lut pin to the Imager node. Load .cube file into this node
- Changed the plugin version number to make it clearer which Octane release it uses
- Added support for Inventor 2019
3.7.0.21 (8-Nov-2017)
- Compiled with Octane 3.07
- Changed "Linear" projection to "XYZ to UVW" to match Octane Standalone
3.6.4.19 (17-Jul-2017)
- Compiled with Octane 3.06.4
- Added Inventor 2018 support
3.6.5.18 (23-Apr-2017)
- Compiled with Octane 3.06. See viewtopic.php?f=24&t=60014 for details
3.5.2.17 (2-Jan-2017)
- Compiled with Octane 3.05.2
3.4.3.17 (3-Nov-2016)
- Compiled with Octane 3.04.3
- Added additional pins to the Falloff Map node as per Octane 3.04
3.3.4.16 (5-Sep-2016)
- Compiled with Octane 3.03.4
3.3.3.16 (12-Aug-2016)
- Compiled with Octane 3.03.3
3.2.0.16 (19-Jun-2016)
- Compiled with Octane 3.02
3.1.1.16 (13-Jun-2016)
- Compiled with Octane 3.01.1
- The Maximum value of the Power of Image maps for Bump maps is now 10
- You can now disconnect the Medium from the Environment Medium pin
- Added new authentication settings window which can be used to activate, and de-activate the plugin
3.0.20.15 (26-May-2016)
- Compiled with Octane 3.0 (3.0.20)
- Fixed issue where the Reflections shadow pass was not working
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
- "Int" nodes can no longer be converted to "Int Resolution" nodes
3.0.10.14 (2-May-2016)
- Compiled with Octane 3 alpha 10 (3.0.10). This means that Render Region is working again, plus many other changes (refer to the Octane Standalone 3 Alpha 10 thread for details)
- Username and password is now not entered or stored in the authentication panel
- Visible Environment pin added to the Rendertarget
3.0.6.13
- Compiled with Octane 3.0 alpha 6. Note the minimum Nvidia driver required is 353
3.0.1.13
- Compiled with Octane 3.0.1 (Octane 3 alpha 2)
- Added Medium and Medium Radius to the Daylight and Texture Environment settings
- Added new Render Passes
- Removed "Ambient" and "Sample Environment" GI Modes from the Direct Light kernel
- Added Deep Image settings to the kernel settings
- Added Baking Camera. The Baking Group Id's cannot be set - so you will need to only render the geometry you want to bake texturemaps for
2.24.2.12
- Compiled with Octane 2.24.2
2.24.1.12
- Compiled with Octane 2.24.1
2.24.0.12
- Added Help button to the Setup form which opens the plugin manual
2.23.2.11
- Added "Abort" button to allow scene loading to be terminated
- Fixed issue where material conversion was not converting Inventor transparent materials to Octane Specular materials. Use the configuration option "Specular Transparency Threshold" to adjust this process
- Materials which are somewhat transparent, but not enough to hit the threshold to become Specular will now have their opacity set to (1 - Inventor material opacity)
- Added Z Axis is Up checkbox to the Configuration screen for user with the Z rather than Y axis up
2.23.2.10
- Compiled with Octane 2.23.2
- Added preliminary support for Surface Bodies which are not part of a Solid Body
2.23.1.9
- Compiled with Octane 2.23.1
- Added Scale Textures option on the Octane material panel to scale all texturemaps and procedural textures for the given material simultaneously
2.22.2.8
- Compiled with Octane 2.22.2. Refer to Octane 2.22.2 Standalone release notes for details.
- Pin changes to the Thin Lens and Panoramic camera stereo settings
- Added support for Inventor 2016
2.22.0.7
- Compiled with Octane 2.22, so includes all Octane 2.21 and 2.22 changes (see Octane Standalone release notes for details)
- Added Light Passes (you can now assign a Light Pass to each Emitter, and then view each light pass as a Render Pass).
- Added Out-of-Core Textures to the Devices tab - where texturemaps can now be stored in CPU/Motherboard RAM if graphic card VRAM is full. Enabling this sets the RAM limit to your total RAM amount.
- Added "Cube Map" project type to the Spherical Camera
- You can now adjust the new Focal Length slider in the Thinlens Camera to adjust the Aperture
Release notes for 2.20.0.6 are:
2.20.0.6
- Compiled with Octane 2.20 (see Octane Standalone for details)
- Added Tooltips to the Octane pins for all nodes in the Setup and Material trees
- Added Materials tab menu options to Copy Material To Clipboard and Paste Material From Clipboard - to allow copy/paste of materials between the plugin and other Octane plugins or Octane Standalone
- Added Polygon Side texture node (see Octane Standalone 2.14 release notes for details)
- Any embedded texturemap files found when importing an ORBX will now be extracted into the LiveDb texturemap folder
I have refreshed the installers at the top of this thread with:
2.22.2.8
I have refreshed the installer at the top of this thread with:
2.23.1.9
2.23.2.11
2.23.2.10
frifer
thanks will test it right away! :)
could you check the download link? it says version 2.23.1.9.. is that correct?
My apologies - that was the old link. It has now been updated.
frifer
thanks!
ps: the cancel button is not anchored properly.
Tnx. Fixed in the next release.
2.24.0.12
Pls note that the on-line manuals are currently offline, so the above Help button will not work until this is rectified by Otoy.
Return to “Autodesk Inventor”
