My comp turns off. Overheating?
PAQUITO
It just happened when rendering with Octane. After about 30 mins. of rendering it just turns off. No warnings, just... boom, you´re off.
After a couple fo minutes it turns on again to normal. Anyone can bring some light about this? I´m really pissed with this, specially in the summer, that´s why I think about overheating.
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
glimpse
Hi, Paquito.
My guess it might be PSU, ..but let's see:
Dowload & install GPUZ,
open a GPUZ window per GPU & activate log files to write all sensors of every GPU (should have separate files for every GPU)
Now work like normal & attach these log files after crash =).. - we'll see if crashes are caused by GPUs =)
PAQUITO
How do I set it to have a long for each card? I have a 690 and there appears two cards with sli enabled. Should I make something special or just leave it as it is?
GTX690
Win8 64.
You can probably just monitor the temperature of one of the 690's (since they are the same card they will have the same temp). Also, my understanding is that you need to DISABLE SLI.
PAQUITO
Sorry, I must disable SLI to work with octane or to make the logs?
GTX690
Win8 64.
whersmy
Also get MSI afterburner to measure gpu temps. You can also monitor if a card has power spikes bumps that are caused by the psu when rendering.
For Octane disable SLI
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
PAQUITO
Could you expand that a little? Why you should disable SLI for Octane? Should I disable also for gaming? What is the difference?
GTX690
Win8 64.
Otoy recommend disabling SLI for rendering (http://render.otoy.com/faqs.php). A number of users have reported that enabling SLI has caused crashes.
PAQUITO
Ok, I see. By now I disabled SLI and will continue working under gpuz monitoring so I can have some info if the problem appears again. Thanks.
GTX690
Win8 64.
whersmy
cool, let us know!
