Okay; so is there like any workaroud about this ? Aside from rendering full image. In Picture Viewer you can scroll things; can scrolls be added to live viewer as well?
I mean in the way it is now , when doing hi-res print work you cant really use render region effectively to see the detail of something because your screen is 1920x1200 and there is no way to navigate images bigger than that. (modo plugin for octane has this funcionality so i tought it kind of obvious to have, my bad).
I understand that i could always just move the camera to see the detail; but that is not a solution when using fog - as camera needs to be outside of the fog for it to be visible, and last but not least i'd rather check how things look in final comp rather than in totally different angle/fov.
I hope that you'll find this request/arguments resonable enough to implement in future iteration of the plugin. (overall i switched from modo to c4d because of Your plugin for octane
