anyone with daz plugin using network rendering maybe? trying to build up a second rig with 3 more gpu next month and wanted to try if this is working with and older comp and gtx580
i installed the slave on second comp, seems to be running, slaveports set to 21001, masterport is 21000. ip range is adjusted correct, firewalls are disabled.
this is the running cmd on slave pc
and this one is from octane standalone on main pc then...
i cant find the slave in the menu... but you can see this "Using 1/1 GPUs" line down below in the main window. in the plugin it also cant be found/detected, so its not working for me... anyone got an idea what this issue could be or how to get it running?
