OctaneRender® for Maya® 2.20 - 6.1 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Maya® plugin, 64-bit.
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on OSX operating system (including and above 10.8).
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Switched to 2.20 engine.
  • Added Octane render layers. You can set the layer ID in the shape's Octane properties and enable layers in Octane general properties.
  • Added Octane Noise texture.
  • Added "Affect alpha" attribute to specular material.
  • Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
  • Removed "Start samples" attribute from passes settings.
  • Removed "Keep environment" attribute from kernels.
  • Fixed "Coherent ratio" attribute bug.
  • Fixed "Polygon side" texture bug.
  • Minor fixes...
Installation:
DOWNLOAD
OctaneRender for Maya - v6.1 OSX (18.2MB autoinstaller file)
Yours,
The OctaneRender™ Team.
p3taoctane
Thanks mate. This fixed my earlier white screen problem.
p3taoctane
All running very well under Yosemite and 2.06 JimStar
Can you please check Maya Network Rendeirng.
I have complete licenses running and operational One for Standalone Master and Maya PLugin Master
Same for Standalone slave machien and Maya PLugin Slave
When using the standalone Mac OSX I can use the slaves from the PC.
When using the Maya Plugin it renders on the MAC but does not see the PC Slaves.
Any ideas.
Peter
p3taoctane wrote:When using the Maya Plugin it renders on the MAC but does not see the PC Slaves.
Do you mean in batch animation rendering, or in IPR too? Are you sure the slaves are not busy by other master process at this time?
p3taoctane
Right now it is just IPR rendering not batch mode.
Slave PC machine is not rendering anything when I am doing the test on the Mac Master. On the slave PC... Maya is open but not rendering anything. The standalone on the PC slave not open.
On the Master Mac Only Maya is open.
On the Mac (Master) the standalone is 2.06
On the Mac Maya (Master) is 2.20-6.1 (OSX)
On PC (Slave) Standalone is 2.06
On PC (Slave) Maya plugin is Win 2.20-6.1
So we all match up
The slave PC Daemon is giving the following message:
Master Daemon has invalid version (7)
failed to decode beacon message from master 128.111.50...... etc.
The Mac Script Editor in verbose mode upon starting render gives no Netwrok render errors
// ****************************** THIN LENS CAMERA ********************************* //
// Name: perspShape //
// Orthographic: 0 //
// Film width: 35.999928, Focal length: 35, calculated FOV: 54.432129 //
// Aperture: 1 //
// Aperture edge: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
// Focal depth: 100 //
// Persp. correction: 0 //
// Stereo mode: 0 //
// Stereo output: 3 //
// Stereo distance: 0.02 //
// Near clip depth: 0.01 //
// Camera: X: 15.251324, Y: 11.402924, Z: 40.575491 //
// Target: X: 0, Y: 0, Z: 0 //
// Up: X: -0.0895104, Y: 0.967098, Z: -0.238139 //
// Octane: Refreshed image, 621 samples per pixel of 16000 //
// Octane: Refreshed image, 4 samples per pixel of 16000 // ......
It shows Slaves: 0, GPUs: 0/0 even though I ran the daemon on the slave and told it to see all the GPUs.
Does this info help trouble shoot
I
p3taoctane wrote:... So we all match up ...
No it doesn't.
You must have the same Octane slave version as the one is running as master.
p3taoctane
Do you mean the Standalone and the plugin must be the same...
Both plugins are 2.20 and the stand alones are 2.6?
p3taoctane
All I can find in the stand-alone is 2.16 not 2.2
Are you ahead of the standalone : > )) ??
p3taoctane
Sorry my bad tying
Both stand alones are 2.06
The plugins are 2.20
Is there a matching set ?
Return to “Autodesk Maya”
