When starting a renderer - let's say the GPU-info says 600 mb free memory.
Is the target image taken in consideration in this value? Is there more memory "to be eaten up" during render time?
About free VRAM...
- martincarlson
- Contact:
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
grimm wrote:Yes, the higher your image resolution is, the higher you memory usage will be.
I think the question was if the memory usage will go up as the render comes along and afaik that is not the case. Higher res uses more memory but that memomry usage is constant from the start of the render to the finish.
Yes, this is correct.Obizzz wrote:grimm wrote:Yes, the higher your image resolution is, the higher you memory usage will be.
- martincarlson
- Contact:
Thanks! The constant usage was exacly what i had in mind.
