jaggy render pass in picture viewer
i can't be sure what do you tried, but likely you says bad colors. If so, try floatbuffer or float(tonemapped) buffer as render buffer type. Also try 16/32(linear) saving options. PSD is recommended.
You have no beauty passes enabled at all, so of course they won't show.
You need to either add the RGBA pass in the C4D multipass system (and enable save in the Multipasses of the C4D Save render settings), or save the render like a regular image, using the Save tab of the C4D Save settings.
Les options multipasses d'Octane ne sauvegardent que les passes assignées à Octane. Dans ton cas, seule la passe ObjectID est activée. Il faut donc que tu sauvegardes la passe RGBA soit en l'ajoûtant aux passes C4D, soit en sauvegardant l'image complète via le menu de sauvegarde de C4D.
