Subdivision levels for different meshes
Short question - how can I control/input different subdivision levels for different meshes? The only option I found is in 'settings' but this applies to all meshes equally.
I'm at work and don't have Octane up in front of me, but you might be able to just select the wrench icon on the mesh node and change the preferences there. I don't know if that just changes the defaults or if it is limited to just the mesh?
Thanks Grimm - that works. The option is kind of hidden. Anyway great it works.
My only concern is that all instances of the same obj (even with copied and pasted separate nodes) have to share the same sub. div. levels. But it is not a problem.
