As soon as I can test I will post any logs should errors arise.
I said I would never use Genesis, but time marches on and you either have to adopt or get left behind
I need more specifics. What character are you loading first? Gen base, Akio 5, or what? Then what mat are you applying next? I need to know exactly what you are doing to reproduce this. It could be you are switching UVs when you apply the new mat.ArtistX1 wrote:for me if I load a Gen/Gen2 character the shader is fine, and all shows as it should, as soon as I change it using a mat that came with the character, then it goes black and that is without me telling Octane to convert it to an octane shader, will try later but will convert the character to octane shaders first, just finished doing a really good image with it so am a little pre-occupied with that atm
