Error loading OCS/ORBX. Local DB
kalain
This error appears when I try to use materials from the local DB;
Error loading OCS/ORBX. Either zero, or multiple disconnected material nodes were found.
I've tried uninstalling and reinstalling, using the latest version of Octane Standalone and the latest Rhino plugin.
Materials straight from the LiveDB (accessed from within Rhino) work ok. However, if I load a liveDB material in the Standalone version, then save it to local DB - it is impossible to use with Rhino.
This problem means that I cannot edit materials for use in the Rhino plugin.
Hi - could you pls send me an example of an ORBX file you are trying to import from the LocalDb? Email to paul at physicalc-software dot com.
kalain
Hi Paul,
Thank you, I have sent the ORBX files.
BR,
Michael
Thanks Michael. File received, and this issue will be fixed in the next release of the plugin (due in the next 24hrs).
kalain
Hi Paul
Thank you, that sounds great. I look forward to upgrading to the latest release.
Michael
Return to “Rhinoceros 3D”
