OctaneRender® for Maya® 2.15 - 6.0 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Switched to 2.15 engine.
  • Some render passes changes.
  • New "Max speed" attribute in info-kernel node.
  • New "Roughness" pin in Diffuse material node.
  • New "Cast illumination" and "Surface brightness" pins in emission nodes.
  • New "Polygon Side" texture.
  • "Distribution" pin of emission nodes is now "Emission pattern".
  • The emission sampling rate can now be set to "0".
  • Removed obsolete "Fstop" and "ISO" pins from the camera imager node.
  • Minor fixes...
Installation:
DOWNLOAD
OctaneRender for Maya - v6.0 Linux (18.2MB autoinstaller file)
Yours,
The OctaneRender™ Team.
JohnMesh
Howdy Jim,
latest build is crashing maya if attempted to load through the plugin manager.
The 2.11.1 - 5.6 Linux [OBSOLETE] version is running fine here on the same machine.
Is there any octaneMaya log you could need?
Next version HERE.
Return to “Autodesk Maya”
