New Texture emision not working
kavorka
We tried making a plane with a texture both as the diffuse and the emitter pattern. When we turned the power up, it looks like the emitter pattern doesn't use the planes UVs. if you rotate around it, the emitter pattern samples different parts of the image at different angles and also has a different scale.
FooZe
The emitter pattern is like the old distribution, so it's for IES lights mainly. If you want to have an emitter surface like a TV then the texture needs to go into the "Texture" input of the emission (the 1st pin).
