2.15 Motion Blur bug
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
couple problems
1 if mb is unchecked it is still there even after refreshed is pressed. octane viewport must be closed and restarted to se mb go away.
2. if network rendering is enabled with mb and COHERENT MODE like 0.3 and time slider is moved (to see moving objects in octane viewport) octane viewport freezes at 1 and mouse turns into spinning circle like max is saving and nothing happens I have to shut off max through task manager. We had this problem long time ago I think
and if mb value is changed nothing happens or a lot of mb happens even on objects that camera followed where you not supposed to have mb and you have to turn off and on octane viewport to see true result
Karba
coilbook wrote:couple problems
I will check
Return to “Bug Reports”
