OctaneRender™ for Blender 2.15 - 7.0 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Switched to 2.15 engine.
  • Octane render passes are implemented.
  • New "Highlight compression" pin in camera imager node.
  • New "Path term. power", "Coherent ratio", "Static noise", "Max speed" pins in kernel nodes.
  • New "Roughness" pin in Diffuse material node.
  • New "Turbulence", "Invert" and "Gamma" pins in Turbulence texture node.
  • New "Hue", "Saturation" and "Contrast" pins in Color Correct texture node.
  • New "Cast illumination" and "Surface brightness" pins in emission nodes.
  • New "Polygon Side" texture.
  • "Distribution" pin of emission nodes is now "Emission pattern"
  • The emission sampling rate can now be set to "0".
  • Removed obsolete "Brightness scale" and "Black level" pins from Color Correct texture node.
  • Removed obsolete "RRprob" pin from kernel nodes.
  • Removed obsolete "Fstop" and "ISO" pins from the camera imager node.
  • Exposure of the camera imager now is scaled differently, so be prepared to that when opening the old scenes in this version.
  • Minor fixes...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.0 Linux (102MB autoinstaller file)
kaiwas
thanks you!!! Work has become faster
grimm
Awesome, thanks Jim! :shock: :) :D
Any chance for a git merge? :D
Jason
mac3d
Hello Jim,i have the problem with OctaneServer :roll:
OctaneServer v. 7.0
Octane: Starting Octane engine...
./OctaneServer: symbol lookup error: ./OctaneServer: undefined symbol: _ZN6Octane20apiMode_Shared_startEPKcbPS1_
Thank you for everything you are doing ;)
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
mac3d
How did you install the plugin? Using auto-installer or manually?
It looks like you don't have the liboctane.so in your /usr/lib folder.
mac3d
Manually,yes i have the liboctane.so in my /usr/lib folder
mac3d wrote:Manually,yes i have the liboctane.so in my /usr/lib folder
Then it may be the old one... From previous version...
mac3d
Resolved, I copied octane.dat and liboctane.so in the /lib
thanks again :D :D
mib2berlin
Hi, thanks for the update (Git too!).
I have a strange error, when I render a file, old or new setup, no objects are rendered only background.
If I switch "Autofocus" off and select one object it render all objects.
If I switch "Autofocus" on again it still work.
I am using auto-installer.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
mib2berlin
Could you please send me the scene where it is reproduceable?..
Return to “Blender”
