Displacement Grass examples (needed)
prehabitat
Hi Reviteers
Anyone had any luck with good displacement grass from Revit?
particularly someone using the standard revit materials as a base...
a screendump of 'working' settings (Revit material w/ displacement node showing in plugin window) and result viewport visible would be great if someone has time!
I tried thismorning (didn't have wifi so didn't check the DB) and was experimenting with noise, dirt texture... neither seemed to work at any power/height.
Do you need noise map/image to handle the displacement to get it to work?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
Check out http://render.otoy.com/forum/viewtopic.php?f=21&t=43025. Also, check the Octane Notes link in my signature for some info on displacement mapping.
prehabitat
Will do, Thanks Paul (Sorry for the caps)
I downloaded the examples and your blog text before I left yesterday (in a hurry obviously! :P)
Had a bit of a look/Play with the example scene and ended up with power around .17 and in the example scene I had the seamless grass 1600x1600 at 0.1 scale (default in that scene) and the displacement 720x720 (?) at .2 (default was 0.05 iirc)... I want a courser grass.
Next I'll play around with colour and less consistency in the displacement (clumpier) ...
Thanks for the pointer in the right direction! :D
Return to “Autodesk Revit”
