Display driver has stopped working and has recovered
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Rik
Try to open the octane viewport and the system hangs after a few seconds, graphics driver reboots with the message "Display driver stopped responding and has recovered" and Nvidia error code3
Have made changes to the TDR delay level but makes no difference.
Changed cards (gtx570 2.5gb and gtx580 3gb) active and priority settings but makes no difference.
tried clay mode, still crashes
not a Vram issue
In desperation, started new scene, put in a teapot with displacement material on and it still crashed
Repeated this process and it worked.
Loaded up initial scene and crashed again. This seems like a bit of a random bug but I think it may be something to do with displacement?
Apologies if this has already been covered but I cant find a solution for this anywhere on the web.
Think it may be something to do with displacement.
Using max 2014 with octane plugin 2.13 and driver 344.75
Any ideas? Currently running out of excuses to stall my customer and they're getting pretty pissed off.
coilbook
Maybe a bug I am still using 2.11a and nvidia 344.11 waiting for more polished updates from otoy and nvidia to be on a safe side
Rik
May have to do the same if the Otoy crew don't have an answer.
If they are there, does any of this help to identify the issue?
Started logging on 03.12.14 13:52:25
OctaneRender version 2.13 (2130000)
CUDA error 999 on device 0: An unknown internal error occurred.
-> kernel execution failed (dl)
device 0: direct lighting failed
-> failed to clear linear 2D device memory
-> failed to load symbol data to the device (kernel data)
device 0: path tracing failed
-> failed to deallocate device memory
-> could not get memory info
device 0: failed to upload data texture 4 of context 0
-> failed to deallocate device array
-> failed to unload module
-> failed to bind device to current thread
device 0: failed to initialize resources
-> failed to allocated device memory
coilbook
i noticed the reason i quit getting cuda errors during animation render is the image clears up a lot quicker in 2.1x version so instead of 4000 samples i only need 2000 samples to get the same results. But if i have to render at 4000 samples i still get 999 and 700 cuda errors no matter how cool i keep my cards, how good are psus. Video cards or this program just cannot handle and freezes after 100 frames
Rik
think I'm slowly narrowing it down to some bits of corrupt geometry or maps or both.
though I bet it ends up being neither and I end up sending the client a painting :(
Rik
It would appear to be displacement causing the display driver to crash...
Tried all versions of octane 2.xxxx
also changed the nvidia driver from the very latest .75 back to 344.11
It's a small model (a house) and when i change the viewpoint in the octane viewport there is no crash - until I turn put displacement on.
Am I the only one still having problems with displacement?
Karba
Rik wrote:It would appear to be displacement causing the display driver to crash...
We have a scene with reproducible issue. I will fix it as soon as I can.
Rik
Thanks Karba
Good to know.
Return to “Bug Reports”
