OctaneRender for Carrara 2.14.0058 [Test]
Carrara (Integrated Plugin developed by Sighman)
Sighman
WARNING: This version has had limited testing. Use at your own risk!
Changes in 2.14.0058
  • Integrated with Octane SDK 2.14
  • Added new Polygon Side shader. (2.14)
  • Support saving new Coherent Ratio attribute. (2.14)
  • Picker is fixed in this version (2.14)
Changes in Version 2.13.0057
  • Integrated with Octane SDK 2.13.
  • Added support for new render pass and info channel options (2.13)
  • Added Backdrop support (Color, Bi-Gradient, or Texture Map).
  • Added new Image Save options that allow the backdrop to be saved with the image.
  • Added animation option to specify file type to generate including file types that include the backdrop.
ATTENTION: This version is based on Octane 2.14. That means you need to update your NVIDIA graphics drivers to at least version 344.x
Happy Rendering...
Download Links:
OctaneRender for Carrara (64-bit) 2.14.0058
OctaneRender for Carrara (32-bit) 2.14.0058
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Tugpsx
Thanks for update. Will check out the picker.
Used it a bit with the last one on this quick project.
Carrara room test
Carrara room test
Sighman
New update posted to this thread.
Tugpsx
LOL you're quick. Ok checking this one out instead.
dustrider
Thanks Sighman!!
ArtistX1
Is there a chance we could have an option to save direct to PSD?
PhilW
I only just got around to upgrading to the latest version - quick question, I am probably being thick but I added a Backdrop in Carrara and couldn't see it in the Octane Render Viewport, is there something extra that I need to do?
Sighman
PhilW wrote:I only just got around to upgrading to the latest version - quick question, I am probably being thick but I added a Backdrop in Carrara and couldn't see it in the Octane Render Viewport, is there something extra that I need to do?
Yep, you need to enable the Alpha channel in the Kernel settings.
Sighman
ArtistX1 wrote:Is there a chance we could have an option to save direct to PSD?
Not unless you know of a free PSD encoder that I can use.
PhilW
Great, thanks Sighman for the fast response!
Return to “Carrara”
