Today i wanted to try out the network rendering feature. The relevant machines in the LAN are DHCP and sharing files works fine. I guess i have to set some firewall rules for network render to work properly since the network preferences window on the master machine stays empty. Any ideas how to set this up? On the slave pc there is only the octane for Lightwave demo installed.
Thanks in advance for any hints!
Need help setting up network render
To configure the native Octane network rendering you need to install Standalone in the render node and set up the slave daemon. But the most important issue is that you need an additional Standalone license for it.
It is better to try to run the network configuration from the Standalone before try to use it in the LightWave plugin.
Here you have some docs to begin with network rendering:
- Standalone and network configuration
http://render.otoy.com/manuals/Standalo ... ge_id=1248
http://render.otoy.com/manuals/Standalo ... ge_id=1269
- LW plugin network rendering
http://render.otoy.com/manuals/Lightwave3D/?page_id=543
I thought i read that no additional license is required for network rendering. At least not the standalone. I am going to purchase another octane for lightwave license for my second machine soon. Did i miss something?
Thanks for the docs you posted, i will study them now.
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
Yes, you need a Standalone license for each render node. If you buy a new combo license (standalone+LW plugin) for your second machine, you will be able to use network rendering between your two machines using the new license.
One license one pc for now.
You might want to vote here.
http://render.otoy.com/forum/viewtopic.php?f=24&t=40732
Thanks for clarifying.
@geo_n: seems like the poll is over. But i also would prefer grimms method.
