Matrix error?
C. RAM Capacity (i.e. 6 GB)
Not sure what is it
- Attachments
- octane 2.11.1 141116 092424.log
- (134.22 KiB) Downloaded 232 times
- stratified
I suspect you're trying to set up a scene with instances? It seems that the transformations for those instances have bogus transformation matrices (they all have a 0 column). Maybe those instances don't have translation but the 2nd and 4th row of those matrices got swapped?coilbook wrote:Not sure what is it
cheers,
Thomas
Thank you. yes I do have a lot of itoo forest instancesstratified wrote:I suspect you're trying to set up a scene with instances? It seems that the transformations for those instances have bogus transformation matrices (they all have a 0 column). Maybe those instances don't have translation but the 2nd and 4th row of those matrices got swapped?coilbook wrote:Not sure what is it
cheers,
Thomas
Looks like forest pack gives you some bad instance positions.coilbook wrote:Thank you. yes I do have a lot of itoo forest instancesstratified wrote:I suspect you're trying to set up a scene with instances? It seems that the transformations for those instances have bogus transformation matrices (they all have a 0 column). Maybe those instances don't have translation but the 2nd and 4th row of those matrices got swapped?coilbook wrote:Not sure what is it
cheers,
Thomas
