Animation
Moderator: BK
Is there a tutorial on how to do animation with the plugin. I setup an animation but it only goes thru the timeline rendering the first frame. No clue of what am I doing wrong.
32 GB of RAM, Sabertooth x79,Intel Crest 180 GB SSD system drive, WD Caviar Black 1TB, i7 3930K CPU,
CoolerMaster Haf 912, CPU Cooler Master Evo fan, Windows 7 Pro SP2, Corsair AX1200 PSU, EVGA GTX 580 3GB Classified Ultra, EVGA GTX 580 3GB Classified
- Spectralis
Have you tried animating from the second frame? I found that sometimes this was necessary with certain projects. Otherwise have you set the frame range correctly?
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
I'm using version 2 beta. I tried your suggestion of starting with the second frame. It didn't work. Instead of rendering all frames with the first frame it renders all frames with the last frame. I'm setting frame range correctly.Spectralis wrote:Have you tried animating from the second frame? I found that sometimes this was necessary with certain projects. Otherwise have you set the frame range correctly?
- blogfather
Im having the same probleme. The plugin is not getting any new geometry from DAZ.
- Spectralis
This must be a new problem introduced in the beta. Hopefully t_3 will be able to offer some advice.
I have the same problem! I bought this to create animations, not for still images. I have time with this and the developer does not fix it this problem, this is a scam.
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
- wendyluvscatz
try 1.2 if you can
I only have 1.2 and it works well, I tried the 1.5 update as not licensed for 2 but it would not update geometry for animation so I am sticking with 1.2
when 2 is no longer an early beta I might consider buying an upgrade but till then I shall laeve it for the art renderers to play with.
Win 10 64-bit CPU Ryzen 3 3600g 32GB RAM graphics RTX2080Ti
