1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
- Fixed coordinate space bug in Projection nodes (reported by aLeXXtoR).
- Fixed modified geometry bug (reported by RajivMudgal).
- Improved license activation proccess. Now you have the separate "Octane server" rollout.
- Linux libs are now included into Linux installer package.
- Minor fixes...
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &DOWNLOAD
Blender Octane Edition - v6.5 Linux (89.7MB autoinstaller file)
