OctaneRender® for Maya® 2.11.1 - 5.5 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed SP5 Viewport 2.0 issue with Octane Sun and Octane Light.
  • Fixed broken ability to interrupt the interactive render by ESC.
  • Fixed displaying of Octane shaders in Viewport 2.0.
  • Fixed Octane texture mapping in UVeditor in case the transform is applied to it.
  • Linux version is moved to Maya 2015.
Installation:
DOWNLOAD
OctaneRender for Maya - v5.5 Linux (16.8MB autoinstaller file)
Yours,
The OctaneRender™ Team.
JohnMesh
Thanks a lot JimStar for this update and move on to maya 2015.
Im not sure but my maya 2015 ext1 sp5 is complaining about a version conflict and an older API used during compilation:
// Error: line 1: Plug-in, "OctanePlugin" was compiled against too old a version of the Maya API and is thus incompatible with the current Maya version. (OctanePlugin)
It was compiled using the SDK from Maya for Linux 2015 (not SP5).
At least in previous versions of Maya the SDK was only incompatible between different versions of Maya, and never between different service packs... :?
Thank you for report, I will check it. If this is the reason - I will release the next version compiled against SP5 tomorrow.
matrix2012
Hi JimStar
Is there now no Linux version for more OctaneRender® for Maya 2014.
It is bad when there is no more support for 2014 for Linux.
Under Windows, there is OctaneRender® for Maya 2013-2015 support.
Next version HERE.
Return to “Autodesk Maya”
