Poser plugin
TheJester87
I've been thinking about buying the Poser plugin for Ocatane. Currently I'm using Daz content in Poser Pro 2014 and I export out .obj. I fire up Octane load the scene and Octane can't find the jpegs for everything in the scene and I have to manually find them for Octane. Not cool! Am I missing something here? And if I were to get the plugin, would I still run across this problem?
Hi - when you export from Poser - it does not put the full path in the MTL file that gets loaded into Octane Standalone when you import an OBJ - so some manual re-linking is required. OctaneRender for Poser does not require you to do this - it will pick up all the texturemaps automatically. There is a demo version you can try to see how this works.
Return to “Poser”
