Octane demo for Modo problem
alexandre.prata.77
I downloaded octane demo for Modo but when initializing Modo i have an error, and in octane log have a message "Failed to initialise CUDA driver API", and octane dont detect any cuda driver in my system.
I have a Nvidia GeForce GTX 650 TI with lastest drives installed an octane standalone demo works fine, only Modo plugin dont work. Please help-me.
In the devices tab in the Setup window, enable (tick) your video card.
"Not installed" for all devices.
Hi - sorry for the problems you are having. I haven't seen this issue before.
Could you pls post the same screenshot from Octane Standalone?
And what release number of Octane Standalone demo and Modo plugin demo are you trying pls?
alexandre.prata.77
Screechot of standalone version work fine
https://www.dropbox.com/s/n6l8o3v9pcwqj ... o.JPG?dl=0
Modo plugin version is OctaneRender_for_Modo_2_0_10_16_64bit_DEMO
Thaks for help
Hi - can you post a screenshot of Octane Standalone File->Preferences->Cuda Devices.
Also, it is worth trying deleting you Modo801.cfg file, and seeing if that makes your graphics card available in the Modo plugin.
alexandre.prata.77
I found the problem, mARCH kit cause the issue. Unnistaling mARCH and octane render work fine.
But i will be happy if mARCH ant Octane work together.
Thanks for the info - I will investigation what might be going wrong here....
I installed mARCH, and the Octane plugin worked fine for me. So either the demo version has an issue, or there might have been something in your Modo801.CFG file which caused the issue. I suspect if you delete Modo801.CFG, and re-activate mARCH, all will be OK. Regardless, the latest commercial version of the Octane plugin works fine with mARCH installed.
