Fur question
LFedit
So I am making a towel, so I wanted to use smaller fur fibers. I am having a hell of a time trying to get modo to bake out such small fur. I got it to work with just a sphere and a fur material, converted to curves and rendered. But just crashing after crashing when I do it for real on the real towel. Is there a way I can just do the fur entirely with an octane over ride or something? Or do I have to do it the baking geo from modo way? Without going into the standalone might I add.
Thanks again
riggles
Are you enabling all options in the bake geo cache dialogue box? I remember having issues sometimes if I disabled any checkboxes, which should really be considered a bug. However, I've successfully baked out the geo for an entire lawn without a crash. Took a while, but I just let it sit and crunch while I took a break.
LFedit
I thought I did at first, but then I tried to just do fur towards the end. I will try it again with them all checked. I ended up just using a displacement map, it turned out pretty good. But I think fur would be better.
Thanks.
Yes - I've seen Modo crash a few times baking fur. Suggest you lodge this with TheFoundry as a Modo bug.
I am hoping by the end of Dec that it will be possible to have the plugin read and render the fur directly from the Fur shader, so the baking step will hopefully not be required.
riggles
face_off wrote:I am hoping by the end of Dec that it will be possible to have the plugin read and render the fur directly from the Fur shader, so the baking step will hopefully not be required.
Paul, that would be so awesome.
LFedit
Yeah I would be really happy about that. Thanks for the input, I will discuss it with those guys. Thanks again.
rubberchicken
It would be great to have Modo fur working in Octane.
I think if you tick Kernel->Render Cache, the Modo Fur Shader will render in Octane.
rubberchicken
Yes, but not cylinders.
rubberchicken wrote:Yes, but not cylinders.
Yes, you need to use strips.
Return to “Foundry Modo”
