Changing Cameras in Animation
LFedit
I built a 360 rig with 25 cameras and have the cameras going around. Then it switches to the next camera at a different angle than goes around, so on and so on. And when I drag the animation slider, it changes to the right camera in the in the octane render viewport, but when I render out an animation, it never switches in the animation render.
The cameras were switching every 100 frames. So now I have 100 frames of the bottom camera going around, but then 2300 frames of the exact same frame 100.
So Basically I can move the animation slider in modo and it changes to the right camera in the octane viewport, but not if I hit render animation.
Thoughts?
Hi.
You need to untick "Load All Frames Into Octane" in this situation - so that the different cameras are picked up when they become enabled in the timeline. You won't be able to render with camera motion blur when using different cameras too.
LFedit
I will give that a go before I leave the office this afternoon. Thanks!
Return to “Foundry Modo”
