OctaneRender™ for Blender 2.06 - 6.4 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
This is the little quick-fix release. It is actual for OSX only, nothing new for other OSes...
  • Fixed bug: crashed in some cases when adding new image texture during Live-Render active.
  • Reworked translation of modified geometry (to address the bug reported by aLeXXtoR).
Installation:
DOWNLOAD
Blender Octane Edition - v6.4 OSX (103MB autoinstaller file)
afecelis
Hi Jim.
I just ran the .pkg and all I can find is in my "Applications" folder is the OctaneServer executable. Where is the blender (octane) executable located?
Also, when I run Octane 2.06 standalone I'm getting the error "no cuda GPUs", but this didn't happen with 1.55. Is 2.06 using a different cuda version? Is there a way to update Mac's nvidia drivers?
regards,
Alvaro
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
afecelis wrote:Hi Jim.
regards,
Alvaro
If you already have blender.app file anywhere on your machine - OSX installer will not install the one from the package. Stupid "logic" in my opinion.
You must remove the blender.app files from other places of your system - then the installer will install blender.app too.
About the GPUs - some archaic CUDA versions were dropped in new Octane releases.
Next version HERE.
afecelis
Thanks a lot JIm. I already installed newer cuda drivers and now with version 6.05 my GPU is showing up fine again. Off to try the new octane-blender version.
regards,
Alvaro
Return to “Blender”
