OctaneRender™ for Blender 2.06 - 6.3 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Switched to Blender 2.72
  • A lot of fixes and improvements
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v6.3 Linux (108MB autoinstaller file)
grimm
Yay! :D Displacement is working great! Thanks,
Jason
mac3d
Thanks Jimstar,fantastic!...
One problem..
Octane: WARNING: only node-textures are supported
Writing: /tmp/contestdisplac.crash.txt
Segmentation fault (core dump created)
Thank you for your work ;) ;)
(15.4 KiB) Downloaded 245 times
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
Synthercat
Still can't export animation to video
Anyone else?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
mib2berlin
Hi Synthercat, does not work for me too.
My own build is working.
May it is easier to render animation to png, exr and use regular Blender version to make a movie out of it until Jim fixed this.
It is better anyway to render to an image strip.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Synthercat
mib2berlin wrote:Hi Synthercat, does not work for me too.
Cheers, mib
You are right mate, that's the way I decided to go for too :)
mib2berlin
I forgot:
Thank you JimStar for the update, work fine. :D
Cheers, mib
Next version HERE.
Return to “Blender”
