Material definition standard
danvica
This is not properly Octane related but not so off-topic I think...
Is there any material definition standard ?
Think having lots of materials already definited in (for example) Luxrender and you want to move to Octane. Would be usefull to just use the same material definition files.
At least in unbiased renderer.
Just a thought.
Win7 64bit | GTX480 | i3 540 3.07GHz | 4GB
in my opinion Octane is too young, we must wait at least till v1.0 final.
anyway interesting thought ;)
PhilBo
As the OctaneLive material database gets filled out, it will be very helpful to all users to quickly add materials to scenes and to also see how some cool materials are made. Is this what you are talking about?
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
jakchit
isn't that what Collada was supposed to accomplish? I'm not sure it's working
win 7-64bit./Ubuntu 64bit 4gb ram. intel core quad q6600, geforce gt430 driver 260.89
danvica
jakchit : Yes, I knew Collada (very little) but I was thinking something limited to material definitions.
In general, it would be usefull to mantain untouched them when moving from one render engine to the other.
There are several "common" standard (step / iges / stl / slp / obj ) to describe the geometric components that you can, more or less, easily use to move from one software to the other... but what about the materials ?
Can the .mtl file format used in Octane be exchanged in other render engines ? And the opposite ?
But really, it's just a tought...
Chris
Mtl files only contains texture locations for the materials in an obj i think.
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
danvica
I don't know what exactly is the mtl file for. I thught was material related but, you're right, I controlled and there're too few info inside.
Actally it contains data for un-textured materials too... anyway my main idea is the same.
matej
.mtl is a very basic description of a material. Just some colors, indexes and image names - not very usable in Octane.
What Octane needs is a good an robust scene & material definition files in XML - an own format that would completely replace the current .obj workaround step. When this will be done and the file specification released, converters from other material specifications into Octane .ocm could be written (by anyone).
cgmo.net
danvica
I agree.
Is there any standard that Refractive software could follow in order to implement the scene + material definition ?
Or every company has a propretary format ?
