OctaneRender® for Maya® 2.11 - 5.3 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2014 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • New 2.11 engine.
  • Fixed mix material UI bug (connecting the materials to attributes using the checker-button).
  • Fixed reshapable proxy motion blur bug.
  • New "Distributed tracing" attribute in passes settings.
  • New "Highlight compression" attribute in imager node.
  • New attributes in "Color correction" texture: Hue, Saturation and Contrast. Brightness scale and black level are removed from this texture.
  • New "Static noise" attribute in direct lighting and path tracing kernels.
Installation:
DOWNLOAD
OctaneRender for Maya - v5.3 Linux (16.8MB autoinstaller file)
Yours,
The OctaneRender™ Team.
Next version HERE.
Return to “Autodesk Maya”
