8 or 8.5?
Carrara (Integrated Plugin developed by Sighman)
gold
Ok, I bought.
Should I use it on 8 or 8.5 ? Or will it run on both at same time?
thanks!
Tugpsx
Works well on both
Sighman
gold wrote:Ok, I bought.
thanks!
The installer will only let you install on one but you can simply copy the files over to the other.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
gold
ok great,
Sounds like I should install both, and get re-acquainted that way. { No carrara is on my machine
current, unfortunately. }
thanks
ArtistX1
I would say it depends on what you are going to use Carrara for, if you plan to use Genesis then yes you will need the buggy 8.5, for anything else 8.1 should do fine
gold
Thank you.
I have both installed. I mainly use V4, although I bought 8.5, mainly for the genesis models.
Hopefully version 9 will address bugs. Would it be cynical, to wonder, if version 9 will be
released at the launch of Genesis 3? To support that new figure? :ugeek:
ArtistX1
With the way daz has treated everyone who has asked about C9 and the lack of information coming from Daz I would have to say "Yes it would be cynical" that they release C9 in time for Genesis 3, if they release a new Carrara at all
Return to “Carrara”
