OctaneRender® for Maya® 2.10 - 5.2 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2014 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed "samples per second" info not updating in IPR mode.
  • Internal motion blur loads several frames into the engine when needed. All shutter settings are now in motion blur section.
  • Minor improvements.
Installation:
DOWNLOAD
OctaneRender for Maya - v5.2 Linux (16.4MB autoinstaller file)
Yours,
The OctaneRender™ Team.
Next version HERE.
Return to “Autodesk Maya”
