deactivate license to use on another computer
g0ll4m
Is this possible? Can I deactivate my license on one computer so I can use Octane on another? and switch back and forth?
Windows 10
Maya 2024.2
2 RTX 4090s 192 gb ram
FooZe
Hi, Yes, you can move your license from one machine to another. You just can't have octane running on more than one machine with the same license.
To deactivate either do it from inside the software or in the customer area of the website. You can do this as many times as you like, but only once per hour.
Just be aware that you will need to deactivate both your plugin and standalone license as they will both be needed on the new machine.
g0ll4m
Ok, thank you, and thanks for the quick reply.
Windows 10
Maya 2024.2
Jeffbarruga
How do I deactivate license and activate it on another computer/
BK
Jeffbarruga wrote:How do I deactivate license and activate it on another computer/
Hi, Jeffbarruga,
The license gets deactivate as soon as you close/Exit Maya. You can check this by signing into your Otoy's account [ www.otoy.com ] then license tab.
or manually sign out from Maya Render settings>OctaneLive>Account status> Signout.
There is also an Unlock option on your license page to use it in case of emergency.
Kind Regards
bk3d
Return to “Autodesk Maya”
