I recently switched to a newer 3ds max version and since then am having an issue with the images aspect ratios. I attached a picture that shows the problem. The octane material seems to pretend that the texture was a square (which it isn't; it is a rectangle as you can see in the image preview) and hence distorts it as you can see in the material editor and the viewport. When checking the image information in the loading window it tells me that the aspect ratio was 1,00 (dunno if that's got something to do with that).
Sry if that's a noob question
Thanks for your answers
