Error when starting Revit 2015
timbarnes
I have Revit 2015, Build: 20140905(x64), Update Release 4.
I also have the plugin version 1.55.0.8.
Running on Windows 7, 64 bit.
After installing the plugin, everything works fine. I can open Octane and render without problems.
If I right click on a Revit file and open with Revit 2015, I get a message saying this:
Failed to initialize the add-in "OctaneRender For Revit" because the assembly "OctaneRender_for_Revit.dll" does not exist.
The file is actually present in C:\Program Files\Autodesk\Revit 2015, so it seems like a startup error of some kind.
If I open Revit without any specific file, and then separately open the file, it's OK.
Any idea what's going on?
Tim
Mac Pro 3,1 / Lion / 14G RAM / ATI HD 2600 / nVidia GTX 470
i5-750 / Windows 7 Pro 64bit / 8G RAM / Quadro FX 580
Revit 2011, SketchUp 8, Rhino
Hi Tim - pls see mid-way thru the installation instructions for an answer on this. http://render.otoy.com/manuals/Revit/?page_id=19
timbarnes
Thanks for the quick reply.
Return to “Autodesk Revit”
