Hi Karba,
there's a problem with the 2.06 version, same data for test between the 1.55 and 2.06: (3dsmax2015)
24 201 860 poly => 2.06 version crash
24 201 860 poly => 1.55 work
Some news about maximum poly and 2.06 vs 1.55 ?
thanks, Oliver
About max 26 843 545 poly
C. RAM Capacity (i.e. 6 GB)
Currently 2.x versions have triangle limitation about 19.173.961 trianglesolivierve wrote:Hi Karba,
thanks, Oliver
thank you for the information, Karba.
I know it is not easy to discuss about the ongoing development for version 2.x, but is there a change to load more triangle in a near future release ?
Remember i have dual quadro k6000, so I'm frustrated !
Oliver
Oliver
What kind of scene do you render? What is the main triangle source?olivierve wrote:thank you for the information, Karba.
Oliver
I work in digital archive of heritage, especially in archeology.
My 3D models are created by 3D scanning. The density of triangles in the geometry is very important and I can not too much decimated models.
Models from 10 million triangles to 100 million triangles (with huge model MentalRay rendering)
with my test i hoped it'll be possible to load near 50 million triangles with the 12Go vram of the Quadro K6000.
so, i'm frustated with the downgraded triangles power 2.1 (19 173 961) vs 1.55 (26 843 545).
Perhaps i'll need to find a dynamic cameara LOD solution.
If you have more information and ideas, i'll keep !
O.
O.
