Single mapping solution ?
scottmclachlan
Hi
I am new to Octane and am struggling with placing decals/mappings onto surfaces.
Have exported surface from C4D with 1 mapped decal which imported as a multiple 'tiled' mapping into Octane.
Could someone please post advice on best way to map single decal onto surface ?
Is there a way to position mapping onto surface accurately inside Octane?...and how ? :?
Many Thanks...be gentle ;)
Scott
Win 7 l Geforce GTX285 (1x) l x980 i.7 64bit 3.33Ghz l 6GB
Win7 l i-7 x980 3.33Ghz l 1xTitanium
jakchit
your model needs UVs and the texture needs to be UV mapped to where you need it to be.
win 7-64bit./Ubuntu 64bit 4gb ram. intel core quad q6600, geforce gt430 driver 260.89
scottmclachlan
Thanks for quick response !
Have mapped onto surface within c4d as usual (with assigned UVW tag).
Am using the c4d (v11.5) plugin for export...still no mapped decal in Octane...missing something obvious ?
jakchit
inside of C4D is this their mapping solution or is it true UV mapping?
scottmclachlan
Good question :? ...this is the only way to map onto surfaces within c4d...as far as I know...switching off 'tiled' surface option allows you to apply single, positionable graphic 'decal'.
The problem is that the mapping is always transfered to Octane as a 'tiled' map...not a single decal...which I need.
Have tried mapping within Octane but have the same problem...cannot find a way of mapping and positioning a single graphic element...it is always 'tiled'.
Have seen many examples of Octane renderings with single 'decal' or map applied to surfaces but suspect other programs have been used for the export.
Have downloaded 'Riptide' obj export plugin for C4D...see if that works !???
Also going to try 'baking' the texture in C4D...see if that works !??
jakchit
well, ive never used C4D
Blender has great UV tools and tutorial videos available.
Perdition
In C4D you have to use Bodypaint 3D to define the UVs. Set the interface to "BP UV Edit".
Intel i7 5960X | 32Gb DDR4 | GTX 980 Ti 6Gb | Windows 10 64bit
scottmclachlan
Thanks Perdition,
Never used Bodypaint...could you please post a really short run-through of the simplest way to do that ?..got a hot deadline !! :|
Really appreciated ! :)
Stromberg90
Maybe just use google, its not that hard to figure out :roll:
Win 7 64-Bit, Q6600, Geforce 9800 GTX+, 4 GB RAM
It's not possible for you saving a polygonal selection and assign a different material for that selection? It works pretty well with the cinema exporter.
