difficulties whit HDRI and mapping
Daniel79
What kind of format of HDRI is best to use ? spherical , etc.
HDRI I can not see a preview of rhino , how can I do?
when I create a material with a color map , bump or normal map , how can I choose which of these to display in preview ?
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
Lat/long (which is the most common format) - not spherical. http://render.otoy.com/manuals/Rhino/?page_id=466
You will need to add the Octane IBL texturemap as a Rhino background environment so it appears in the Rhino render preview. At some point this may be able to be automated (I will add it to the list). Alternatively- load the IBL into Rhino, tick the "Sync Octane Enviro to Rhino Enviro" option in the plugin Settings tree, and set the Octane "Environment" texture to an RGB Image, set the Octane "Environment"->"Projection" to "Spherical" and set the Y Rotation to 90 (and the Rhino Environment should be bought across).
There are some changing coming to this area.....stay tuned.....
Daniel79
And for the question about the material what i can do?
Daniel79 wrote:when I create a material with a color map , bump or normal map , how can I choose which of these to display in preview ?
Only the diffuse map displays at the moment. There has been much discussion on this, so some additional functionality may be added in the future.
Return to “Rhinoceros 3D”
