Render elements most important for compositing.
We need render elements include to the octane render 3ds max plugin.
When will you add the render elements or will you add in the future ?
Can you reply ?
Thank you.
Render Elements
Render Elements already exist. Go to Render Setup > Kernel > Kernel Type: set to Info Channel and then in the Info Channel, select the channel you want to render (OA, MatID, ObjID, ZDepth,...)
The problem, to my knowledge, is that you have to do it one by one... waste of time. A fix would be to allow Render States Sets to work with Octane. Hopefully in a new version. Render State Sets are very useful.
e483278 wrote:Render Elements already exist. Go to Render Setup > Kernel > Kernel Type: set to Info Channel and then in the Info Channel, select the channel you want to render (OA, MatID, ObjID, ZDepth,...)
Check out Version 2.1
