OctaneRender™ for Blender 2.06 - 6.0 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Network rendering
  • Displacement mapping
  • Hair and Fur
  • Rounded Edges
  • Random Color texture
  • Improved Sky rendering
  • Region Rendering
  • OpenSubDiv support
  • A lot of minor improvements...
Installation:
DOWNLOAD
Blender Octane Edition - v6.0 OSX (98.9MB autoinstaller file)
marknorbert
Wow, great news!
But unfortunately I can't start the Render Server (all previous versions worked very well). In the console I'm getting the following error message:
Dyld Error Message:
  Library not loaded: @rpath/libcudart.dylib
  Referenced from: /Applications/OctaneServer.app/Contents/MacOS/liboctane.dylib
  Reason: image not found
Thanks for report. I will check it.
Yes, I see the little OSX version issue. Will fix it tomorrow in next release.
Next version HERE.
Return to “Blender”
